Avogadro33
Member
Calling All Pilot Radio Corp. Gurus ---- Help Needed
Years 1961 - 1962
Beginning 1960 or 1961, Pilot Radio Corp. expanded their line of hi-fi products by introducing receivers: the Model 602 and Model 654.
The Model 602 had a stereo pre-amp, 30-watt stereo amplifier (15-watts per channel) and AM and FM tuners. This, of course, was the era prior to the FCC officially adopting the Zenith/GE standard for Multiplex FM stereo. Radio stations broadcasted in stereo by sending the left channel signal over their FM band and the right channel over their AM band. The receiving unit had to have both FM and AM tuners, each tuned-in to the specified frequency on the respective bands. At the time of the design and manufacture of the Pilot 602 and 654 receivers, a stereo broadcast required this dual FM/AM tuner set-up.
Model 654 ---- The Pilot Model 654 receiver used the same pre-amp and FM and AM tuners as the Model 602; however, it incorporated a more powerful 44-watt (22-watts per channel) stereo power amplifier.
KEY POINT: Based on expectations that the FCC would soon adopt a nationwide standard for broadcast and reception of a multiplex FM stereo signal, external FM multiplex adaptors were beginning to be introduced by various manufacturers of hi-fi equipment. At the same time, manufacturers were readying their latest tuners and receivers for the new technology by including provisions for an external, plug-in FM multiplexor. Both Pilot Models 602 and 654 had an RCA input jack on the rear of the chassis for a plug-in multiplex adaptor.
In 1961, the FCC selected the Zenith/GE-developed “Multiplex” technology standard over competing technologies for broadcasting FM stereo. However, it would be another year or so until built-in FM multiplexing was the norm on consumer tuners and receivers.
Years 1962 - 1963
Model 602M ---- In 1962, Pilot introduced the Model 602M receiver (sold in 1962 and 1963). It had the same pre-amp and 30-watt (15-watts per channel) power amplifier as the Model 602, but now incorporated a built-in FM stereo multiplexor, thereby able to receive and decode a single FM stereo signal as broadcasted by the radio station into two-channel stereo sound. In addition, the 602M had what Pilot referred to as an “Automatic FM Stereo Indicator Light”, which turned on when it detected a stereo FM signal. The tuner on the Model 602M was FM only (no AM).
Model 602S ---- At the same time as the 602M, Pilot introduced the Model 602S. It was the same as the Model 602M but is also included an AM tuner. The 602S cost $50 more than the 602M.
Model 654M ---- Accompanying the introduction of the new 602M and 602S, Pilot introduces the 654M. Whereas the original Model 654 receiver had a 44-watt (22-watts per channel) stereo power amplifier, the 654M bumped that up to a 60 watt (30 watts per channel) stereo power amplifier. The 645M also had built-in FM Stereo MPX tuning with an automatic FM stereo indicator light.
WHERE THE MYSTERY APPEARS
At some point, Pilot sold a Model 602MA, 602SA and 654MA. There is no question that there were “MA” models. I have literature and actual receivers in my collection with faceplates having printed designations 602MA, 602SA and 654MA.
It appears, however, that the 602MA was the same as the 602M, and even Pilot’s advertising literature seems to use the two designations interchangeably. There seems to be no available information regarding the differences, if any, between the 602M and the 602MA, though some speculation has to do with how or where the models were sold.
Similarly, the Pilot 602SA is the same as the 602MA except also having an AM tuner. Further, and as with the 602M and 602MA designations, I do not know if there were in fact differences between the Model 602S and 602SA.
Finally, and keeping with the pattern observed with the smaller-brothers Model 602M and 602MA, Pilot produced, and designated as such, a Model 654MA receiver. It appears, however, that the 654M and 654MA were in fact the same. Again, even Pilot’s advertising literature seems to use the two designations interchangeably. I thus do not know what were the differences, if any, between the 654M and the 654MA.
Does anyone know what were the differences, if any, between any of the following pairs:
The Pilot Model 602M and 602MA receivers?
The Pilot Model 602S and 602SA receivers?
The Pilot Model 654M and 654MA receivers?
In other words, what was the “A” all about?
Thank you.
Years 1961 - 1962
Years 1962 - 1963
Thank you.
