So I picked up a pair of Visonik HiFi 'David 7000' monitors and a 'Sub 1' (passive sub), but will need help sourcing the correct foam for the mid/woofs. Also, one tweeter is blown. I'll have to find someone who can fix it or find a used one. Any tips on who to ask would be great. It's too bad the monitors don't have rubber surrounds like the sub does, which all look very similar to ADS drivers.
This is a cool set and I can't wait to bring it back to life. I'd be interested in any literature on the David 7000 and Sub 1, if anyone has some to share. Being an M&K fanboy, I've heard of Visonik from the David & Goliath combo they marketed, but this is my first hands on experience with Visonik gear. Any help and/or tips would be appreciated!
EDIT: I found some info on these little speakers here, just right-click and translate to english; http://www.hifi-wiki.de/index.php/Visonik_David_7000
"General
"General
- Manufacturer: Visonik
- Model: David 7000
- Years: around 1980
- Made in Germany
- Color: black, walnut
- Dimensions: 250 x 161 x 170 mm (HxWxD)
- Weight: 4.5 kg
- Factory price approx .:
- Design: 2-way closed, compact / wall loudspeaker
- Chassis:
- Woofer: 1x 130 mm
- Tweeter: 1x 25 mm (dome)
- Power rating (nominal / music):? / 70 W
- Efficiency: 86dB (1W / 1m)
- Frequency response:
- 70 - 17,000 Hz (± 2 dB)
- 40 - 25,000 Hz (+ 4 / -8 dB)
- Transition ranges: 2,500 Hz
- Impedance: 4 - 8 Ohm
- LED overload indicator for the tweeter"
