Retrovert
Addicted Member
Be careful with the spec. It's +/- 200 v MAX. Peak or 100v Max, steady state.
Yes, there are two values, depending upon whether the heater is positive or negative. I've explained why the disparity exists.
You are correct that it specifies 100 VDC maximum, which is unrealistic as it exceeds the insulation's limits.
