Can a quality RCA cable make that much difference?
wasclywabbit
When the going gets wierd, the wierd turn pro.
Decided to upgrade the cable from my CCA to my receiver. Had a cheap generic one. Replaced it with an Evergreen Audio (long grain copper, asymmetrical double balanced geometry, etc.). $50 at Best Buy. I'm noticing a major improvement sound wise, especially in the low end. My subs sound totally transformed. Kind of a rhetorical question, but can a cable really make that much difference?15978760943057388961756178455426.jpg
If it is in the signal path, the answer is yes. How much of a difference depends on how much difference you are hearing. Some say a lot. Some say a little. The important thing here is that $50 is reasonable money.
Yes sometimes.
In my case yes and no. I tried some nice cables years ago when my electronics weren't as nice and I could not hear a difference. I gave the same cabling a try once again a few years later after several electronics upgrades and then yes the difference was and still is audible.
My experience says Yes.
The first time I noticed an improvement was when I replaced the cables provided with my first CD player with some AQ cables.
Over the years I've upgraded RCA, USB, ethernet, balanced and speaker cables with good results.
For sure, especially if the old cables are thinly insulated or are corroded on the contacts. A good quality cable is always the right choice. Snake oil is never the right choice.
These are superior to the Evergreens, at a lower cost. I mean they sound better, IMHO.
Just bought another 6' set for $30.00 delivered.
Neutrik Rean RCA plugs are the best. The heft, the contacts, the cord relief end caps.
Silver Plated copper strands, silver plated mesh sheilds, PTFE insulation, small outside diameter, and very flexible.
They sound better than entry level Straight Wires, Audioquest, Tara Labs. I'll PM the vendor contact to anyone interested. Not affiliated.
My guess is that your original cable was compromised in some way. Cheap interconnects may not be shielded very well at all. Those Evergreen cables are shielded well. The long grain OFC wire construction is audiophile Mumbo jumbo. The double balanced asymmetrical geometry sounds like BS on the surface to me. Unfortunately, I couldn’t find much on their site to explain it, and of course, no specifications. Reading one of their docs regarding “directional” cables, they have some theories, and end it with “ as always, the proof is in the listening”
Of course the proof is subjective...when you have no proof. If anything, you got a well constructed cable and $50 didn’t break the bank.if you’re happy with them, good for you.
I ask the same question every time I respond to one of these cable threads. How does an engineer design a cable, or anything for that matter, without the ability to measure the results?
How did the AudioQuest R&D lab determine which design went to production? When they have a spool of raw wire delivered (assuming they manufacture the cables), how do they know which end is which since it is ‘directional’?
If I manufactured cars and I told you I made the fastest production car on earth, you would ask how fast does it go. What would you think if I never said how fast, but just that the proof is in driving it. Buy one and you’ll feel how fast it is. This is what the claims by the expensive wire manufacturers sounds like to me. They make claims that should be easy to confirm, yet they avoid measurements like Dracula avoids sunlight.
Directional just means which end of the shield is grounded to which RCA plug. It makes very little difference.
IIRC, the arrows should point away from the source, in the direction of flow (toward the amp).
You don't need $1000 cables to connect a $100 CD player but if you spent $10k on a CD player you might notice a difference between a $10 cable and a $1k cable.
Typically the cables that come with the equipment when new are fairly low quality / performance and can easily and inexpensively be improved.
First impressions, after a long time becoming accustomed to a system without changes, are the most reliable and informative, IMO. I'm talking about a day's worth of first impressions, from your current rotation plus some familiar favorites. If I actually hear new things on familiar recordings, then I know I have an upgrade. Differences smaller than that are a matter of personal taste, but no less valid, IMO.
You have your answer.
Take that, direct experience deniers!
While AudioQuest utilizes this method to make cables directional, they also claim their wire is directional :
“While most are either unaware of conductor directionality or have chosen to ignore it, we have learned to use conductor directionality to our advantage.”
And of course, no measurements to confirm directional quality. “ the proof is in the listening”
Sounds like BS to me.
Silver plating on copper strands, that's the real deal. Surface effect of free electrons.
Signal comes down the pike like a freight train that's lost it's air brakes.
:D
