beatcomber
AK Member
Quick question -
I've recently put my 100% stock AR-XA back into my main system and am wondering if the suspension can be adjusted enough to support a 16 oz brass record weight, or are the springs just not strong enough?
Right now, it's tuned perfectly for use without a weight, and so I wanted to check in here before I go messing around with it. A quick Google image search pulled up zero images of AR-XAs with weights (excepting heavily modded tables), which makes me suspect that it's not a good idea to use one with this table.
) that I suppose that everything is done for a very good reason.
