I'm putting together a smallish amp that will be using a voltage doubler PS. In order to have a nicer under-the-chassis layout, I plan to stuff one of the vintage cans and mount it up top.
Are there any objections against stuffing both doubler caps, screen, and driver supply caps into the same can?
Obviously, doubler caps will be insulated from the can. I typically do not ground my stuffed capacitors to the can common and run separate ground leads out to correct ground points. This one will have 2 ground leads. One for doubler + screen and another one for driver/inverter.
Thanks for your thoughts!
