Greetings!
I have a Harman Kardon 6100 (simplest model, 2x30 W, 22 A) that has no sockets for externarl amplifier. Would it still be possible to use it as a preamp and hook up a poweramp via tape out?
Cheers!
Olle
But of course - volume control might be good to have!
What do you mean by “the amp” on which you can use the volume control?If you can use the volume control on the amp, why is it so dangerous?
If you can use the volume control on the amp, why is it so dangerous? What difference does it make whether the volume control is on the pre-source or the amp?
Interresting! I think I understand the concept but am a bit slow today. Do they form a chain of amplifiers, connected via tape out to aux? All have separate volume controls, and the source is hooked up to the first amplifier?I have 3 integrated amps and a receiver connected tape Rec to aux. (output to input).
The volume comes in at source volume but the connected amp has volume control on it just like other aux inputs.
The benefit is all amps have same music and I plug in speakers to all the amps. So increasing speaker capacity. 6 sets.
So you need volume control at the power amp.
This is actually called "daisy chaining".Do they form a chain of amplifiers, connected via tape out to aux?
Except that the potentiometers usually used for input attenuators on most power amplifiers were not spec'd, designed, or constructed for long term continuous rotation/adjustment like the high quality ALPS pots used in many decent preamplifiers.Some power amplifiers do have level controls, and will work just fine except that there will be no tone (bass & treble) controls.
FYI, my Dynaco power amp just has regular volume controls and they are very robust. Been twiddling them for 30+ years and still dead silent and work factory fresh. Of course, it was built right back in the day. They are even on the front and are very accurately calibrated and channel matched. But you are right that a lot of even very expensive basic amps have junk attenuators because they are cheap and the engineers assume they won't be used. Accountants are generally the jerks who insist on this sort of "efficiency".Most tape/rec outs run around 150mV fixed. Most consumer power amplifiers have an input sensitivity between 750mV and 1.5 volts(1500mV) required for full power out. Connecting tape out directly to the power amp inputs probably isn't going to break anything right away. But, it's going to be loud with no volume control, and it's going to sound pretty "dry" with no tone controls or loudness contour in the signal path.
The solution as mentioned above is a proper preamplifier.
