That would probably be an easy repair fix with a good wood glue and coffee filter paper material. Cut a patch and put it on the back side to set. I've seen and done many fixes like this with good results and no re-tearing.
Good luck to your repair!
DC
DC
I have seen people use rolling papers - thinner and stronger compared to filter papers. This is due to since fact that rolling paper is made from materials other than wood or is a blend of wood pulp with other materials (like flax). The fibers are longer hence stronger and thinner.
Do condoms work as well??
