Well, I ended up buying this amp from
@dslavey , and a working one as well. To his credit, he disclosed that parts are hard to find.
Murata no longer makes thermistors with lugs on them like the one that was missing from this amp. However, they still apparently follow the same coding convention for them. So, I selected one with the coding BD, which is the curie point, and 222 which translates to 2.2 K ohm.
Then to make it a lug mount I cut open a ring terminal:
Then I put the thermistor inside it and expoxied it:
Here it is mounted on the heat sink assembly:
The amp had suffered catastrophic failure; 6 of the 8 outputs had shorted, 2 shorted drivers, many open fusible resistors and a bad zener. It and its companion are now making music, and I've got to say that even on my bench speakers these things show a lot of refined grunt!
The moral of the story is that when some things aren't available you just have to improvise.
