My WAG here is that in some instances where the passive is now being moved by box pressure rather than the motor's kinetic force, the coil and former might not travel in the same linear path causing rubbing, just my WAG.It is necessary to remove the motor?
Making a guess here, you shouldn't have to remove the motor. So long as you don't jumper the leads, the coil in the magnetic field shouldn't affect the motion of the cone as a passive.
Heck if you want them I have a pair of polk 10" passives you can have for shipping. Drop me a PM if they would be of use to you.
I'll take them! THANKS :thmbsp: PM sent.
K
... removal of the magnet would allow you to access the voices coil and backside of the dustcap. That is where you would add mass (epoxy putty, a washer or two glued on with silicone, etc) to the cone in order to lower resonance.
Shop tip...
Tape that old woofer magnet to the end of an old mop handle, broomstick, etc. Use it to "mine sweep" the floor to find dropped screws and other small parts.
