Can I plug two 4ohm speakers into this unit?
Maomaster
Hello, I recently purchased a Kenwood KR-1000. Which gets some flak in these threads over the design of the unit, but regardless of its looks, it has some serious power. I see this on the back of the unit, and begin asking myself..."does that mean I can run two 4ohm sets of speakers (B+C) and not risk killing my receiver???" Please advise this noob before he kills someone...or more importantly...someTHING...
According to the manual, when two pair of speakers are to be operated in combination that are 4 ohms or more, connections are to be made at the "B" & "C" terminals and the Impedance Switch should be set to 8 Ohms or more. Presumably this means that the speakers are wired in series when using these connections.
However this switch must be set Less than 8 Ohms to when: 1) A single pair of speakers rated less than 8 ohms is used. 2) When two pairs of speakers connected to A, B (or C) are to be used in combination. (No minimum impedance stated).
That said, I'd be extra cautious when driving two pair of 4 ohm speakers using the connection method directly above calling for the "Less than 8 ohms" position of the impedance switch. The resulting impedance will be 2 ohms and will likely fall significantly lower than that at certain frequencies. Since the manual only provides output power ratings of 120WPC & 130WPC into 8 and 4 ohm loads respectively, it is evident this is not a unit designed with high current capabilities, ie operation into < 2 ohm loads, therefore the output stages are likely be overloaded under such use.
Link to the Owner's Manual. Will have to register with hifiengine to view.
https://www.hifiengine.com/manual_library/kenwood/kr-1000.shtml
THANK YOU!! I had found the manual before, but found it to be almost MORE confusing, so I sincerely appreciate the guidance. I think I'll just stick with running one set of 4ohm speakers at a time. One for rocking (MTX AAL1540) and one for softer, more subtle music (Advent Laureates). Again, thank you for helping me not blow up my unit, I know it looks unconventional, but being a child of the 80's....I kinda like it :)
Plus, the sound is analog still....so it's kind of the best of both worlds to a younger, aspiring audio-padawan...
It depends on the speaker. Unfortunately some manufacturers are very conservative in their ratings and some not so much. Most modern mid-price speakers are very easy to drive. They know that they have a good chance of being hooked up to some gutless HT receiver and will be judged accordingly.
Much like most numbers in audio, a grain of salt is recommended.
Have in mind that not all the speakers are created equally...to translate in english.Nominal impendance may be 4 ohm but different speaker can have impendance dip lower than 4 ohm, more over different speakers have different impendance dip across the hz band. One can dip 2 ohm in 40 hz, second set of speakers can dip in 500 hz...all this is very stressful for the amp ( need a really good amp to handle this without issues ).
I wouldn't play it b+c...one pair at the time should be ok, depending on your amp spec.
