Are you sure it's really solid copper core? Much (dare I say most??) RG-6 intended for CATV use is copper plated steel core.
As far as the calculation and response of rolloff, there is not enough or the correct information to say, but I doubt it's an issue at any audio frequency, considering RG-6 coaxial cable often has bandwidth ratings to 1GHz or more.
The rolloff is based on total capacitance and the source/output impedance, not the input impedance, afaik.
If I calculate based on 1,000 ohms source output impedance (fairly high for a source, so it's conservative in the rolloff calculation), 17pf/m capacitance, and 10m cable length, I get rolloff of -3dB at ~936kHz. This is well above the audio frequency so even if you "back track" the -3dB, I think it's not hard to envision little if any effect at audio frequencies.
If you want solid core, Belden 1694A, or want smaller diameter and flexible, Belden 1505F, and the Gepco stuff mentioned looks good too.
I used RG-6 with RCA adapters for a sub cable for a while and it seemed to work fine. However, I "stole" that for a long coaxial digital interconnect and simply made a new sub cable from some shielded twisted pair wire I had around. That seems to work fine too.
Regardless of the cheapest raw cable you buy and any half-way decent ends, I think you'd be hard pressed to even make one for less than what you can buy preassembled from Monoprice.
