waynegreen
The following are AC voltages measured between the shield (ground) of an RCA cable plugged into an EMU 0404 Sound card and the shield (ground) of a second RCA cable plugged into the AUX input of an SX-1250 receiver. The cables are connected ONLY by the test leads from a FLUKE RMS voltmeter. The computer remained on for all measurements. The computer is plugged into a standard 3 prong surge protector using a standard 3 prong power cable. The surge protector is plugged into a standard 3 prong wall outlet. The receiver is plugged into the same surge protector using a non polarized
2 prong plug. Obviously there are two possible orientations of the Receiver plug. Below are the measured voltages as well as the frequency indicated by the Hz button on the meter.
ORENTATION A
Receiver Power OFF: 104V @60Hz
Receiver Power ON: 36V @60Hz
ORENTATION B
Receiver Power OFF: 2V @60Hz
Receiver Power ON: 75V @60Hz
Seems like the preferred orientation of the Receiver plug is B but
why is the Receiver ground shifting when the power is turned on?
(leaky cap?) Is the 75V a danger to the SC?
ORENTATION A
ORENTATION B
