Aillo
There is no cable gauge you can use that would damage your Marantz 1070.
Ok. That settles it. Thx again.
Well then, who was it for. FWIW, I spoon fed you the most important piece of information that could prevent you from damaging your amp that this whole thread produced.My message wasn't to you the skipper. I just don't understand why people keep recommending thicker cables. We already know about that stuff. Yes, it is much better. I got it. We all got it I guess.
Well then, who was it for. FWIW, I gave you the most important piece of information for your situation that this whole thread produced. You're welcome.
Some people think fatter cables will mean better performance and unless the cable runs are very long, it makes ZERO difference in most systems. Your system will work fine with good quality 16 awg wire, period. Since the run is a bit on the long side, 14awg would work to but probably not make any difference. Neither one will hurt your 1070 in any way.
The thinner the cable, the higher the resistance...which I think you now understand, if you did not before. Also, the longer the cable, the higher the resistance.
The higher the resistance, the lower the output of the amplifier. Effectively, the power capability of your amplifier is reduced as resistance goes up. Practically, this means that you will have to turn it up a bit more than you would need to with thicker or shorter cable to get the same loudness. This effect will not be dramatic...maybe 10% or so in you planned arrangement. This will not damage the amplifier....it will only reduce its output capability.
As for running both pairs of speakers simultaneously...don't do it. As was pointed out above, the resistive load on the amp from two pairs of speakers is greater than with one pair. This forces the amp to generate more current (or at least, it tries to) than it was designed to provide. In turn, this can damage the power supply components and/or the output transistors.
The suggestions above for using a speaker selector box with impedance protection are right on target if you ever do want to run both pairs simultaneously. The protection circuitry assure that impedance (resistance) will not drop below a specified level (usually 4-6 ohms), but it also may have some small effect on sound quality.
This of course assumes that your amplifier (receiver) is designed to handle the load presented by the selector box. Just about all receivers can handle 8 ohms, and many - but not all - can handle a 4 ohm load.
As a cheap fix, you could add 4 ohms in series with each Alesis speaker to make their load 8 Ohms a piece. But you will lose half the volume in those speakers. I did this in my last AV receiver hookup using a 4 Ohm JBL center channel speaker. Worked well for many years.Ok. Thx for all the super quick answers!
That is a good point. My Alesis speakers are 4 ohms and the JBLs should be 8 ohms. So you do not recommend using both at the same time, am I right? Could you explain why?
It may well be that Purcell's music has little in the way of dynamics; I am not interested in it enough to look at his scores. This does not change the fact that classical music in general has the widest variance between softest and loudest elements (dynamic range) and also the largest crest factors (the difference between average and peak levels).
As for Mark B's experience, it is hard to know what type of distortion he was hearing, and its cause. As I noted, the difference in resistance would not seem to be large enough to make a significant difference in audible clipping distortion.
