ConradH
Lunatic Member
While rebuilding a Marantz receiver (2230) and having previously rebuilt a Sansui 2000x, I wondered about sound, economics and conventional wisdom.
Both receivers sound really great. Both receivers have single supplies and capacitively coupled power amps, not dual supplies and direct output coupling. I had always thought the former design was done purely to save money, and the more desirable design was always a full complimentary dual supply design.
Back when these were built, big can capacitors were quite cheap, unlike the inflated prices we have today. If you use one big cap for the power supply, and 2 caps to couple the outputs, that's 3 caps. But, you got the savings of not using power PNP output transistors, though I'm not sure how great those savings were. I do know PNP performance back then wasn't what it is today.
With a dual supply complimentary design you just have 2 power supply caps. The price and performance of PNP devices is very good today, so that should be the more economical design.
So...
1) How much of the "sound" of these receivers might be due to the "inferior" cap coupled design?
2) Is there any real reason to build a single supply cap coupled amp these days?
3) Why do you think they chose to go single supply back then?
So...
