digiface
First of all, noob alert. This is actually a Roland DEP-5 rather than hifi audio but I'm trying to ascertain what the damage actually is and whether this can be / is worth fixing. I've read other posts and looked at pictures and still not sure whether this is glue corrosion or electrolyte leakage, some kind of corrosion caused by mixture of both or even a fire. There is glue on the bigger capacitors at the top left , but a lot of the damage I've tried to highlight is around the smaller capacitors which probably didn't need glue .. and other similar capacitors have no glue. The unit actually still works but occaisonally there's some crackling in the output .. I thought it was the relays as this is a known fault and I didn't bother looking inside before thy arrived .. doh.
The battery also need replacing as that's corroded and is possibly impiclated .. guessing that's what the corrosion is from on the frame where maybe the unit has been stored leant against a wall .. dont know.
EDIT: I'm beginning to think IS actually really dried out old glue , that for some reason has been applied to small clusters of caps but not all, that has badly corroded and started to eat away at the traces and surroundinng components.. I've counted 28 that probably need or should be replaced. Hmm.
