Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Hello,
I am trying to replace the caps in a pair of Dahlquist M905s. I opened them up and found 2- T1 capacitors. I wasn't sure how to interpret the value. Might someone know the value of these and what would be the best replacement? Thanks,
gb
No mystery here. The markings on those caps are standard for that type of cap. The first two digits are the capacitance value in microfarads, the letter is the tolerance of the capacitance value, the final part is the voltage rating or dielectric breakdown voltage. For example, "10 K 100 V" means 10 uF +/- 10 % tolerance with 100 V maximum voltage.
Why? Now that you are inside looking at the goods and find out they are good, by looks not measurement but not 'lytics that change over time, you can probably leave them alone and go attack some other chunk of gear in your stable. But as stated you can get into some fancy caps, audyn, clarity or some such brands, not the common stuff and improve things. You already have good, common stuff.
Enjoy the journey and let us know what you slap in there and how it sounds.
Replacing the cheap mylar film caps with Audyn A4's (10uF @4.57 ea. and parallel 3.9 & 2.2 uFd (yeah, it.s 6.1 but that's no big deal) 4.59 for both. That's $18.32 for both speakers. A very worthwhile investment. I'd probably replace the 5W sand cast resistors with 10W non-inductive resistors (less than $1.50 each). Total damages: $25.00. Leave the inductors alone.
Thanks everyone. Thanks for the spot on cap interpretation!! Joe at Regnar (Dahlquist) returned my call readily. He said while the caps could very likely check out within tolerance, they have found a marked sonic degradation. He didn't push a replacemtn but predicted a noticable improvement with replacement. A friend also recommended replacing the tweeter ferrofluid while I am at it. All told, about $35 in parts for the refresh.
