raco
Greetings,
Here's my second post in 5 minutes
I'm thinking of possibilities to upgrade my Mac 1700, as many people like its SS pre/amp sound and I'm thinking that either my ear is defective (might just be) or there's plenty space for some critical parts replacement as most likely they're all original (it's actually in quite collectible shape).
Experience taught me that power supply upgrades / maintenance have the most pregnant effect in the sense of bringing back to spec / improvement due to new technology.
For the power amplifier (4000/50), searching here I found two recommendations, a Mallory Computer Grade cap that sounds OK as a choice to me, and a Panasonic EE series that sounds better to me but has to be near extinction, as I did not manage to find it in stock anywhere. Any other choices you guys / gals favor? Physical size, certainly, has to be at least very near original cap's size.
Regarding the multisection filtering cap for the HV PS (tuner), anybody's aware of an exact replacement? The other route, also indicated here, is using multiple Nichicon PW series caps for each section. Any other solutions apparent to anybody reading this?
My other handy trick is replacing the rectifiers with UF / MUR ultrafast type.
Any other suggestions for maintenance / upgrades for this receiver are welcome. Same stands for my other affair, tuner MR-65.
Thaank you!
Best regards,
Radu.
Thaank you!
Best regards,
Radu.
