Hi, I have a Citation 22 I bought new in 1989, that I took apart to chase down a DC output issue. I'm thinking the DC output may be related to cracked solder joints in the pre-driver board with loose transistors, as when I moved that board or banged it, the DC output would increase or go away. I'll know when I put it all back together.
While taken apart I saw some capacitors that looked really bad and pulled a few to test. It turns out the bad looking ones were mainly damaged by a corrosive glue that was used to hold the larger ones in place. They looked terrible, but measured fine, for example the 470 mf / 100V ones measured pretty much spot on with ESR of 0.5 ohm, even after 30 plus years. I did however find that most if not all the 10mf/50v ones were bad or measured very poorly. I also found a few bad 100mf/16v caps, a few bad 330mf/16v caps, two failed 47mf/10v, and two totally failed 2,200 mf / 6.3V ones. Once I took them out, I replaced them with fresh ones as it made no sense to reinstall 35 year old parts. I used Nichicon PW for power supply related ones (330mf, 470mf), Muse ES for the 100 mf coupling input caps. I do however have a question about 5 capacitors on each side that I am not sure if they are coupling, power related or what else. Initially I thought they may be coupling caps and I was going to use Nichicon ES bipolar caps, but I also have some Nichicon FG audio ones I could use. I don't know enough about electronics to understand the schematic. I'm not sure what these caps do, and which would be more appropriate, maybe a more power oriented cap like the PW are called for here. I would really appreciate some help from those of you that actually understand schematics and what things do. I am enclosing a picture of the position of caps in question.
The question is; what do the 10mf/16v caps highlighted do, and should I use Muse ES bi-polar (supposedly very good as coupling caps), Nichicon FG (fine gold), or instead use a power related capacitor like the Nichicon PW???
Thanks,
Andrew
Thanks,
Andrew
