Capacitor replacements
kears
Hi everyone,I'm a newbie to the forum so go easy on me,I have a question,I have a pair of Mordaunt Short Festival 2 speakers and want to recap them,can anyone tell me what I need to order ....the old caps are 10uf 50v. And 5uf 50v elcaps.... like capacitor types ..electrolytic film etc and what values i can safely use if i cant get the same values thats in the speakers,i hope im making sense.....
The old saying is...if it's not broke don't fix it....i thought it would mean I would get a Better sound...after all the caps are 40 years old.
yes
maybe better, maybe worse
I've replaced capacitors in crossovers 50 years old and didn't hear any difference.
I think it's much more important to replace old capacitors in amplifiers than in speaker crossovers.
@kears , on the other hand, if these are your speakers and crossovers, maybe it wouldn't be a bad idea to change the caps
more on "elcaps"
yes
don't say that, i'm supposed to embark on a big cap job!
How old are the caps, and what kind are they? If its 20 year old no names, change them. If its some real brand less than 30 years old its probably OK. If they are 50+, change them.
I'd definitely change them. Caps from 40 years ago may have degraded, and probably weren't as good as what you can get now. Only you can decide whether or not it makes an audible difference.....every system and situation is different, but there's a good chance you will if the rest of the system is up to snuff.
While at it, I might even upgrade any sand cast resistors with non-inductive wire wounds if there are any and if they're accessible.
Personally, I wouldn't get rid of "sand cast" resistors and swap them for wirewound resistors. There's a good chance that those "sand cast" resistors are wirewound anyway.
It seems to me that an angry mob has formed on forums and they're out to get "sand cast resistors" without even knowing what they are.
As for the capacitors, it would do no harm to replace them and it might give you peace of mind. For 5uF you could use polyester or polypropylene without them being too big or costing a fortune. For 50uF you might have to stick with electrolytic due to size/cost restrictions.
Thanks everyone for your Help..im having difficult in getting the 5uf cap in my area will a 4.7uf be OK..
I think 4.7uf will be fine. You can always parallel a 0.22uf bypass cap to get closer to 5uf.
Parts Express has 5.0uf capacitors, they're not cheap.
"Non-Inductive" is a key element when upgrading resistors IMHO. That's something I could hear in the treble when I switched 30 years ago. No anger about it all...it's just better to eliminate another variable when possible. It's fairly cheap, and usually fairly easy. :bigok:
Yes, I agree, a resistor with significant inductance wouldn't be a good idea. I'm not sure though how much inductance there would be from a resistor of a few ohms, as typical in a loudspeaker crossover.
Thank you all for your Help...If you see a Mushroom Cloud in the Direction of Ireland don't Panic its probably Me after changing the Caps...
Good luck, have fun and always remember that greatness has been achieved by those who dared to screw up!
Here are some measurements with a HP 4275A LCZ bridge. A 1 ohm, 5 watt; 10 ohm, 10 watt; 5ohm, 10 watt, 4.7 ohm 2 watt. Inductance is so small as to be negligible. The inductance of the wiring inside the speaker is probably on the same order. Measured at 10 KHz. Inductive reactance @ 10 KHz: .7 uH=.04 ohms; 1.2 uH=.07 ohms; 1.3 uH=.08 ohms; .3 uH=.02 ohms. The Q of these is so low as to be unmeasurable by the 4275A at 10 KHz, but at 1 MHz the Q of one I measured was 0.8.
This is not a concern.
If the speakers currently have electrolytic or bad or crappy film caps like Elcaps then recapping with good quality film caps should increase sound quality.
