GrisPato
I spend most of my time on the "Sansui Exclusive" forum. I also scroll past the new messages frequently and lately notice a lot of comments about ripple current when members advice other members about choosing capacitors.
Often the advice is : the one with the highest ripple current!
First, I get the impression, when it is said that way, people think it is a "current amount the capacitor can deliver" parameter. But it is a rating of how high a ripple current the capacitor can endure, consistently at the temperature rating and life expectancy.
Second, how do you calculate the maximum ripple current a capacitor will see in a certain amplifier?
The only thing I can find is on the site of Rod Elliot, Sound.au, where he says 2 X the maximum current your amplifier can deliver.
This would mean with a power amplifier of 100 W@8ohm/150 W@4ohm /channel at a rail voltage of 45 V at maximum power, 2,5-3,5 A x 2 = 5-7 A/ channel.
This would mean that the life expectancy if you would run a signal that would output maximum power continuously ( impossible playing music ) @ rated temperature ( what is not common but can be) is doubled. When the temperature is 10° C lower it will double again, etc.
Even more interesting is it for the local decoupling capacitors on the PCB. They often see practically now ripple current. Can I say, in the mA. So how would it matter for choosing a capacitor if the ripple current rating is, let's say a 470uF-63V capacitor, 800 mA or 1300 mA. Do you have to use this for the filtering of rectified AC for a pre amp? Yes, there it matters, for local decoupling I would say not.
Does this make sense?
Do I see this wrong?
What am I missing?
I would love to hear people's opinions!
What am I missing?
