waggs098
I'm working on a receiver that has a hum to the speakers. I want to find out if it's the filter caps causing it. The ones in the unit are 56v 10000uf. I checked actual voltage at the caps and it's 50.4v.
I have some used caps that are 50v 8000uf. Would it be ok to use these just to do some testing? Of course if I get the unit working properly I will order the correct caps to put in before any heavy use. Just don't want to spend anything until I know I can get it working properly.
Thanks
Justin
Thanks
Justin
