Pioneer A-70 Upgrade Kit Audio Capacitors
https://www.audio-high-store.com/product/pioneer-a-70-upgrade-kit-audio-capacitors/
€30 for 32 Nichicon audio capacitors sounds quite reasonable to me, is it too reasonable to be true.
Hi Paul.
The confusion over choosing replacement capacitors does appear to raise a lot of eyebrows and comes up a lot. I agree with others here in that it is usually the PSU that should be the first port-of-call, and leaving those caps out isn't a good move. I too found that 'audio high store' company while looking for a way of recapping my Sansui AU-222. I haven't had any experience with them, but their kit prices do look fairly reasonable. But in the end I used a tiny little shop in Solihull, near Birmingham called BitsBox who ordered me some ELNA Silmic II's and some Panasonic FC caps and they were very reasonable- they prefer to work online and via email, because their 'shop' is only really a trade counter, and it's absolutely tiny. Unlike Mouser or RS they won't charge silly money for postage or caps in minimum amounts of 5, 10 or even 200 even though you may only need one, and if they think there is a demand for audio caps, they'll get them in for you- which they will as I found out. It seems the guitar FX pedal building community love using high quality audio caps- especially Panasonics and ELNA Silmics. So audio amp supplies, no problem.
Do spend a lot of time researching what you need though, because it seems not all e-caps are the same. Some will work for longer at higher temperatures (not always needed in the actual audio circuit, but most probably in the power circuits) and some are just for the extremely paranoid, or more to the point, Nichicons which appear to come in so many different versions, yet some engineers out there think that this could be excessive unless you are repairing really high-end equipment, and nothing less will do. And even then...
Hi-Fi Collective in High Wycombe seem like a good place too, although somewhat pricey, and more aimed at constructors of valve-based equipment. But they do sell Nichicons and ELNA's.
Also it really helps having a copy of the service manual too, so you can make a BOM from that. Some of the caps in my Sansui are no longer available- like 500µF. 470µF should work fine as a substitute, but just make sure the voltage rating is either the same or higher. Never lower! And modern caps are also way smaller than they were 30-50 years ago. This really threw me at first. So did 'radial' types vs 'plug in' types. The latter being bigger than the radial types, and even then the spacing between pins/legs on the caps can be different to what they were 30 years ago. All very annoying!
I watched this excellent video recently on YT, which really helped if and when choosing Nichicons (although Panasonic FC's or ELNA's look like they'll do just fine too)
I hope this helps alleviate some of the confusion!
Tom (Birmingham)
