Superman541
Well-Known Member
Forgive me. I need you to verify and/or clarify what I think I know about capacitors and how to choose them. Here is what I think I know:
They store and release an electric charge. Their ability to do this is capacitance. Measured in microfarads - uf.
They also have voltage and tolerance ratings, which should be printed on the body of the capacitor.
I may decide to replace some capacitors and perhaps other parts in my new Pilot 690A, which is discussed in a nearby thread, and I will have specific questions about that unit, in that thread. In the meantime, I am hoping to get clear on how to assemble a list of caps I need. For this, I may need to look at each capacitor and jot down the voltage, capacitance and tolerance ratings. I should make sure the capacitor I get is rated for no less voltage than the capacitor I am replacing. I think the tolerance should also at least match or exceed the capacitor I am replacing (percentage tolerance should be as low or lower than the cap I am replacing). Finally, the capacitance should be about the same, but not necessarily matching. A little higher capacitance rating is often acceptable.
Do I have this right?
Another question: There are different TYPES of capacitors. Electrolytics are different from others. Right? Some capacitors in a given amp have more effect on sound than others. Some audio guys choose specific brands and types of capacitors because of their performance. Two caps with identical ratings might still perform differently. Do I have that right?
