Trekkie4
Retired Member
Hi guys!
After almost 18 years of wandering in digital jungle, I finally found my way out & am going back to vinyl & analogue technology lol. So now I'm looking at my choices regarding cartridges, styli & their upgrade(s). I would also love to hear your input on my current setup & any suggestions on how to improve its quality
So, first things first - the turntable itself. Now, I know some of you here will probably roll your eyes but overall speaking I'm quite happy with my choice - Audio Technica AT-LP120 USB (black). Being the latest gen edition, It came with AT95E cart & HS10 headshell just like LP5.
However, I happened to have a very old Shure M94E cart in my desk drawer from around early 2000s, so I gave it a try. This Shure barely had 50-ish hrs of service before it was removed from the headshell & stored back into the original box.
Unfortunately, it seems that after 18yrs of waiting stylus suspension gave out, as the sound quality suddenly turned from bad to worse - things started out OK, but then I noticed audible distortion on right channel. Which led to loud crackling & static, very similar experience to the one from dirty & worn records (except it was ONLY on right channel) So, I ordered a replacement stylus & this is where things get really complicated - apparently Shure M94E is no longer available, either a genuine Shure N94 stylus or replacement one. Instead, I could choose between N92E & N97xE which is essentially the same stylus as N94, but slightly dressed up to include brush stabilizer & fancier guard. Sadly, I wasn't in financial position to buy N97xE at the time (especially since 97 is pretty expensive) so I went with N92E replacement instead.
And this is the weird part - despite the quality & size difference (0.4x0.7 for M92 vs 0.2x0.7 for M94E), not to mention frequency response (20-18,000Hz for M92E vs 20-22,000Hz for M94E) I can barely tell the difference between those two! In fact, the sound quality is far more better, because now I'm getting clear sound without any distortions on either of the two channels. But it still makes me feel bad for downgrading, going from "better" to "budget" if you know what I mean. Do you think I should look into upgrading to Ortofon OM 5E and/or Audio Technica AT95EX, would that give me advantage over current setup? Because I already got AT95 cart, I would only need to swap the stylus for "EX" one. Both OM5E & 95EX are 0.3x0.7 elliptical styli, and capable of higher frequency response than Shure M92E. But then again, OM5E's internal impedance & inductance are far less than the one on M94. Because remember, even though this is now M92E stylus, it's still mounted on M94 cart which seems to have different values than P-Mount M92 one.
If it's OK with admins here on forum, I can even upload sound sample(s), I got "Dancing Queen" from Abba ripped from my LP album in three flavors - AT95E, Shure M94E & Shure M92E (on M94 cart)
