Cartridge help.
RD Airlines
Hello AKers!
I have been collecting equipment for a bit and am just now considering improving my tt performance by switching out carts and buying a new stylus or two. I’ve been using the carts that came with the tts but I’m not sure how old the stylus’ (styli?) are and will probably improve sound by swapping them out.
TTs: I have a Marantz 6300, a 6100 and a technics sl 1200. All currently operating in separate systems.
Carts in play (currently on tts):
Stanton 500 II
2x AT (not certain the models)
Carts on the sideline:
AT 8008 (new)
Shure V 15 type IV
Grado G-1
I’m thinking about a new stylus for the Grado and the Shure and getting them onto the Marantz tts.
I’m considering what to do with the AT 8008 and if it should be used on the technics. (I do not like the sound of the technics as much as the Marantz and I think it’s because of the Stanton.). I’m also considering selling the 8008 to get another Shure IV for the technics.
What do you think?
thank you!
59398C4A-8FC3-4E0B-B9B3-0A8F10F88AF7.jpeg FAA98560-7145-4CAD-8BBF-D6F6B6D3BC6A.jpeg 5817DBEE-407D-4D02-9888-F4DD309C5DC0.jpeg 4E00E1DA-8FE2-41C6-A320-0A3E54C6B77B.jpeg D2FBA2CF-97EA-4648-875C-3A86BB637C87.jpeg 08C27E36-F6C9-4E28-A4AD-8632697D1687.jpeg
The AT 8008 is a highly coveted P-mount cartridge for those who have the better T4P turntables. You could use it on the SL-1200 with an adapter. However, there are those who believe that the plastic 1/2" adapter is not the best solution and impact sound quality. There are better solutions, such as the Technics SH-90S P-mount headshell for Technics S-tonearms, but expensive. You are probably better off selling the AT 8008 and getting a 1/2" mount cartridge of your preference.
Ah, ok. See, I’m learning something.
I was unaware of the compatibility issue with the 8008. Knowing that makes me think that I should take your advice, sell it and get a new cart for the technics. Maybe I’ll try out the Grado and Shure once I have them up and running. Assuming I can swap the headshell between the Marantz and Technics.
Thank you.
Thank you.
LPGear.com sells a fantastic JICO replacement stylus for that Shure. Mine's a type II but the stylus sounds incredible, sometimes too revealing (detailed but will really display albums that aren't perfectly clean).
Thank you.
The headshells will physically interchange between tables. However, the alignment may not. I'm not sure if the Marantz and Technics are the same tonearm geometry. I would verify before doing cartridge swaps across platforms...
I believe that is a conical stylus on the 500 -- an elliptical would improve it. Cheap enough at Voice of Music, and easier than swapping the cartridge. Should have a very flat frequency response with slightly rolled off upper end, it was a standard broadcast cartridge for ages, and was made in various iterations through the DJ years.
Shure V15 type IV was the flagship Shure back in the day, unless you don't like the Shure sound it's a great cartridge. I find I like Stanton 680 family ones better, but that's because I have a preference for strong high ends, usually lacking on a Shure cartridge even with a top end stylus.
You should be able to get Black Diamond nude styli for all of those cartridges, and unless you get a bad one they will be a fairly inexpensive improvement over a worn one.
I used to be a big fan of Stanton carts although I never had a 500. I still have 2 600ee's and would upgrade the stylus if I was going to use them again.
I bought a Stanton 600 in 1982, still have it. Haven't used it since 1993 though. I currently have several Stanton 7x7 carts, plus some Pickering equivalents and like them much better than my various Shure P-mounts.
I'm a fan of the various HE profiles. A good nude elliptical can offer plenty of detail, but the HE styli are MUCH better. This includes the Fine Line, as used on the 2M Bronze. These styli are easier to align than the more exotic profiles, being less sensitive to parameters such as SRA, VTA, and azimuth. For tables that lack tonearm height adjustments, this is the easiest path to higher end sound, in my opinion.
Not really. The 8008 is the ubiquitous AT wedge p-mount cartridge that was sold under at least 20 names. Internally, it’s a very close sibling of the AT95. The 8008 had a red stylus grip and was a bonded LC stylus. With varying styli, it was sold as the 1001, 2002, 3003, 6006, 100x, 301, 311, 331LP (identical to the 8008), 3472, and many, many more badges. Styli for it are plentiful. LPGear has several styli for it, including the Vivid Line which is a bonded LC stylus like the original 8008 stylus. Also conicals and ellipticals can be had. LP Gear also sells that same cartridge body under several badges.
I mostly listen to my Marantz 6300, so I'm inclined to put the V15 type IV onto that turntable. However, I have heard that the V15 type IV is not a great match for the 6300 due to the weight of the tonearm and stock headshell.
I have heard that it ends up being muted, I'm assuming due to the weight? I do not want to lose the highs and clarity of the music and am concerned that if I install the V15 onto the 6300 I will. What do you think?
Alternatively, I heard (posted above) that the V15 IS a good match for the Technics SL1200. I do have a Grado G1 that I could match with an 8MZ stylus for the 6300 if that would be a better match. I don't know.
I'm asking all of these opinions because trial and error with new stylus will begin to get very expensive, so I'm leaning on the experts here.
Looking forward to your thoughts. Thank you!
I'd consider trying something brand new. A quality replacement stylus costs almost as much as a whole new cartridge, and I'm inclined to suggest a modern Nagaoka or Ortofon or even a current model AT instead of aftermarket styli for old cartridges from the 1980s. Especially with Shures where you can only buy aftermarket.
Hello AKers!
Stanton 500 II
AT 8008 (new)
Shure V 15 type IV
Grado G-1
What do you think?
thank you!
View attachment 2413358 View attachment 2413359 View attachment 2413360 View attachment 2413361 View attachment 2413362 View attachment 2413363
I love the ML & SH. CLICK BELOW...
https://www.audio-technica.com/en-us/cartridges/line-series/at-vm95-series
Brand new will hardly get you out of high expense. It may exacerbate your spending limitations (we all have those). Replacement styli .*alone* will run higher than a Jico SAS/B.
For the Shure V15 Type IV, the aftermarket styli quality is very well documented both in here, and in VE, as is the cartridge. Verdict is still out on new offerings, in how they compare, and on that arm. Also, the Jico for the V15 IV has the dynamic stabilizer brush that is still effective for helping damp/match the cart and tonearm resonance and tracking.
I'm very intrigued by new options, but because I have these vintage carts - and they are generally liked - I'm inclined to see what they can do. My concern is how to best match them up to turntables. I've heard that the V15 doesn't match up too well with the 6300 but I've also read how others like the combo quite a bit. I might go ahead and make the Jico SAS/B plunge and see what kind of result I get on the 6300. If it's not great maybe the V15 will move over to the 1200.
The V15 carts (and all other Shures) that use a stylus with damper brush can be used in many/most tonearms. It's one of the brilliant aspects of these Shure carts that gets, ahem, brushed aside too often.
My ‘77 Hitachi HT-460 has a very similar mass arm as your Marantz. The Jico stylus on the V15 IV has no problems whatsoever.
