lamstx
I picked up a pristine Pioneer PL-L1000 earlier today and I'm drawing a blank on what cartridge it came with? Google lens said it was pretty much every cartridge that you can buy a yellow stylus for.
I would appreciate a replacement stylus recommendation also as this one is pretty bent. $150-$300 range.
I bought it as non-working for $125, and it looks like they simply had the power setting set to 220 rather than 120. I do still need to clean it up and DeoxIT the controls, but otherwise everything works as it should.
Thanks, pictures attached.
That PN-600 stylus doesn't look like it will work as intended on the OP's cartridge.
