iplagolf
Well-Known Member
Hello, a little back ground. I have a Technics SL-Q3 with a new Shure M97xE cart. and stylus. My other table is a Yamaha YP-D4 with an Empire 2000 PE. I acquired a Sherwood S-5500 III about 2 months ago (tube amp) Myself and a very qualified tech went through the amp. New 7868 out-put tubes, resistors, re-biased, etc. the amp is like new. I run several RTR decks through a switch box and a CD player. The tone and volume with the RTR's and CD is as it should be. With the volume control at the 10 o'clock position comfortable level of sound. This amp has a phono gain. It was cleaned while being serviced. I hooked the Technics table up and the sound was very weak at the same levels as the RTR's and CD. I have to turn the volume up twice as much to get the same volume level. The phono gain is turned up as much as it can be. When I back it off just a MM I lose all sound. Thinking the gain was still dirty I was going to pull it off line and clean it again. Before I did that I hooked the Yamaha up. The sound was equal to the RTR's and CD player at the same positions of the volume knob. I could turn the gain down to past the halfway before losing sound. I'm at a loss. I can find no information on the Empire cartridge via Google or on this sites data base. The Shure is wired and installed as it should be. Any ideas as to what I'm missing here? Thank you in advance. Fritz
