Hello, looking for help/advice on my Carver PM-175. I bought it use ~2002. Had several guitar effect rack preamps that I'd run into the carver (left channel only) then output (left channel only) to a full range/PA-type cab I built with a 15", 10" and bullet horn (pretty sure 8ohm). Also pretty sure it wasn't in mono bridge mode (wouldn't have known what that was at the time). I gigged in a band using that several times. Guessing around 2005 was last time I used the amp, I don't recall it having any issues, pretty sure it was working fine. Been stored indoors since.
Opened it up for the first time and noticed the burn marks inside, realized the snubber film cap on right channel had overheated, cracked and spilled out contents, possibly onto the left channel's resistor. For all I know it was already like that when I got it used, but more likely could have been the reason why I stopped using it. Unfortunately I don't remember.
Any ideas what would have caused this. Sounds like high frequency oscillations/high voltage to zobel/snubber network but assuming something must have failed upstream. I assume if I replaced the cap and resistors it would likely happen again. Wondering if it did burn when I was using it and I didn't noticed it because I've only ever used the left channel? Don't know if I ever even tried hooking up the right channel to a speaker.
I appreciate any help you can give!
