after you pull the cover off, there will be a thin bar that the meters are mounted to. they will have 2 small screws, one at each end.
pull the bar off and the meters will/ should come out with them, if not just pull them back.
the lights will be behind them.
ive seen led replacements on the bay in diffrent colors. i think i may score a set of the red led's for mine.
you will need an angled phillips screw driver for the 2 screws as the heat sinks are kinda in the way.
good luck(its easy):thmbsp:
-vic
