Carver+Denon Vs. Denon
LTHinch
Hello,
Considering only 2 channels (L+R) being driven through a pair of Klipsch R-1s'..
using a DENON AVR-3805 internal pre amp and amplification either bi-amp or non using this one unit... 120 RMS@ 8ohm or almost double wattage with bi-amp.
or
use a CARVER PM-600 amp 200 RMS@8ohm
and utilize the pre amplifier section from the DENON mentioned above.
Please note that this is a no money/what if scenario using what is immediately available...
I am simply curious what someone else might consider setting up or what I might be neglecting.
Best Regards
Hello,
or
Best Regards
Crown pre amps never let me down with clipping or distorting. Pushes Cerwyn Vega 15s on -1 will rattle the framing off whatever room it’s in.
