1nutSquirrel
Actually, I have two questions...lol
1.) I am using the carver with a Mitsubishi DA-P20 preamp and a Carver TX-2
Tuner.....also with a pioneer 707 / and a couple of Tascam 133's...
The question is when I turn the preamp up to about 40...
It starts out at -70 and goes as high as 40 and then it goes back down to 1...
( hope I didn't lose you...check out a da-p and you'll see what I mean )
It's in laymans terms...turned up about 1/4 of the way...it seems to shutdown.
All the lights etc are on but no sound...?
oh yeah, forgot to mention...I am using Klipsch RP-3 speakers...
specs below for them....
frequency response 27Hz-20kHz±3dB
power handling 110 watts maximum continuous (300 watts peak)
sensitivity 95dB @ 1watt/1meter
nominal impedance 8 ohms
tweeter K-105-K 1" (2.54cm) Titanium dome compression driver
high frequency horn 6" square 90°x60° Tractrix® Horn
midrange K-1081-S 6.5" (16.51cm) Aluminum cone / cast polymer frame
subwoofer K-1082-K 10" (25.4cm) Fiber-composite cone
Is it possible I am over driving them and it is causing the shut down ?
The Carver amp lights don't move off the lower set...but I have seen them
go above that...so I know they are working...
Question 2...
The Carver is a magnetic field amplifier...
In what proxsimity (sp) should I be concerned with the "field" having and
effect on either a tape deck or a tv ?
Sorry for the rant in the first question but I was just trying to give as much information as I could to avoid a ton of questions...
Thank you for your support and help
Question 2...
