n1ims
I've recently replaced several blown/open/shorted components in the right channel of a Carver TFM-35X that I received, dead. I'm looking for recommendations on how to best test this. Unfortunately, the mechanical design doesn't lend itself to easily getting to both sides of the board, so it pretty much has to go completely back together, so I even if I didn't mind blowing through parts with repeated tests, it would take forever.
Is it possible/safe/wise to use a dim bulb tester or variac on this design of amplifier? I've found conflicting info on whether this is a plain jane class a/b amp or one of their more outside of the box designs.
I'm also puzzled by the use of a rubber gasket between the power transistors and heat sink with no grease. Should I add the traditional compound when reassembling it?
If anyone is curious, I can provide the details on what I found for dead components in the right channel and what I replaced. I'll attach a link to the schematic for reference.
thanks,
Dave
http://carvermanuals.com/manuals/Amplifiers/TFM-35x Service.pdf
thanks,
Dave
