I was given a pair of Castle ISIS speakers by a family member (i have no knowledge of the speaker's prior use/history) and I'm also completely new to the world of Audio, so please forgive me if I'm not using the correct terminology.
when I first set them up the sound quality was good, however, the second any bass was played through both speakers emitted a fuzzy sound, on inspection I found the rubber sounds were basically falling off, so I removed the existing glue residue and re-glued the surrounds back on, this appeared to fix the main extent of the fuzziness, with the left speaker sounding perfect, however, the right speaker still sounded fuzzy with any bass, particularly at higher volumes.
I've removed the back of the speaker and everything appears to be in place, correctly soldered etc. and i removed the driver and cannot see anything immediately visually wrong.
the only thing that seems to be out of the ordinary is that if i gently press down on the white cone as it moves there is a scratching sound and it feels & sounds as if something is rubbing/Scratching against it.
I would appreciate any advice/guidance on what or if there is anything i can do to remedy this
n.b I've included photos in a below reply for reference
