INTRODUCTION
The Celestion SL6 was introduced in 1982 and is a very high quality mini-monitor design made
in England with high quality parts and construction. The woofer and tweeter face plates
are aluminum metal as is the woofer chassis. All mounting hardware is backed by metal thread
inserts. The crossover is on a printed circuit board (PCB) and all wiring is soldered to provide
gas tight connections.
WOOFER ENGINEERING
Celestion engineers employed laser interferometry as a means to view cone and dome motion
across the radiating area vs. frequency in order to minimize breakup and non-pistonic
behavior. Just one optimization is that the woofer cone is molded in one piece including the
dust cap. In later versions, the woofer outer edge is a split design made from two different
rubber materials to provide a further optimization.
TWEETER ENGINEERING
The tweeter is a 1.25" copper dome made of one piece with the voice coil former and also
optimized to minimize and push breakup modes above the audio spectrum. However, the
stiff metal break up while much higher in frequency is much stronger such that it must be
notched in the crossover. Copper being heavy resulted in lower efficiency than most tweeters
and as a result the SL6 has a somewhat depressed top end.
ADVANCED CABINET MATERIAL FOR DERIVATIVE DESIGNS
Seeking a better cabinet material, Celestion engineers chose an aircraft aluminum with an
internal honeycomb structure called Aerolam. The SL600 is an SL6 in an Aerolam cabinet
with a significant price premium due to the difficulties in constructing such a cabinet. The
SL600Si is a minor update to the SL600 with bi-amp/wire inputs and star grounding in the
crossover but is otherwise identical, as far as I know, with the early drivers. SL600Si Review
in Stereophile note the price of $1995/pr not including stands:
https://www.stereophile.com/standloudspeakers/744/index.html
The SL700 employs the later aluminum dome tweeter and split edge woofer in an Aerolam
cabinet: https://www.stereophile.com/standloudspeakers/488/index.html
The SL600, SL600Si, and SL700 were John Atkinson's at home reference speakers for many years.
Back to the SL6:
Reviewers have made favorable comparisons to Quad electrostatics finding them to be very
similar but noting the slightly depressed top end of the SL6. All later versions of the SL6
including the SL6S, SL6Si, and SL700 employed the next revision 1.25" aluminum dome
tweeter with higher sensitivity and were voiced to correct the depressed top end.
Several reviews, linked below, provide much more detail about the Celestion SL6:
HiFi News and Record Review - First published in 1982:
Note that their measurements were made with the microphone half way between the tweeter
and woofer. I've found that the SL6Si and SL700 measure best on the tweeter axis and they
probably would have gotten better results.
https://www.hifinews.com/content/celestion-sl6-loudspeaker
More info on the SL6, not that I agree with all the comments:
https://www.muzines.co.uk/articles/celestion-sl6-speakers/4076
https://audionostalgia.co.uk/celestion-sl6-review/
SL6S (NEWER MODEL) review in Stereophile 1987, $900 a pair - the new aluminum dome tweeter is mentioned:
https://www.stereophile.com/content/celestion-sl6s-loudspeaker
This site provides a tweeter repair service and a lot of information and parts:
https://carpwrangleronline.weebly.com/
SPECIFIC SL6 PAIR COVERED IN THIS THREAD
I bought a pair of SL6 s with drivers looking in good shape but with one tweeter not working.
Update 4-8-2022:
I rejected replacing the copper tweeter due to the depressed top end and the fact that the
crossover must be factory aligned to the high Q metal dome resonance. I then considered the
later aluminum dome tweeter from Celestion but after seeing the measurement of that tweeter
in Stereophile and the high cost these were also rejected. See the poor tweeter response
above 10KHz in Figure 1 - I wonder if this was a single defective sample of that tweeter:
https://www.stereophile.com/content/celestion-sl700-loudspeaker-1991-measurements
I decided to repair these with Dayton RST28F (silk dome) tweeters. I had these on hand with
the truncated face plate and there is also an aluminum version that could be adapted for those
who wish to retain an aluminum dome tweeter. The Dayton tweeter replacement will be
covered in another thread.
TWEETERS
It's interesting that one copper tweeter dome looks shiny, the other looks like it was
subjected to high heat and is badly discolored. The copper tweeters require factory matching
of the crossover notch filter to the particular tweeter. The "factory alignment" involved two
inductors, one to position the notch filter, and another to trim the output at high frequency
probably 15KHz or so. The later Celestion aluminum dome
tweeter is claimed to have a dome resonance above the audio band that does not require a
notch filter. However, as stated above this later tweeter does not measure well. I purchased a
single SL6Si with the aluminum tweeter in order to have an example of the newer woofer,
tweeter, and crossover. the SL6Si crossover does not require any factory alignment and the
crossover was simplified with two inductors and one capacitor eliminated. The SL6Si will be
WOOFERS
I pulled one woofer and the spider looks like it has sagged by 1/8" or more, really
looks more like 3/16", is this a common problem? I've noticed it to be fairly common
with rubber edged woofers for them to sag. Has anyone else noticed this problem?
I'll try to get a picture of the sag.
CABINETS
Strange that one cabinet has heavy scratches and dented corners, it's as if one sat on a
concrete floor and was slid around and even turned over and slid more, perhaps the other
was on top and not as badly beat up with only minor scratches.
WOOFER ENGINEERING
TWEETER ENGINEERING
Back to the SL6:
Update 4-8-2022:
TWEETERS
WOOFERS
CABINETS
