Center post on 9 pin and 7 pin miniature tube sockets
currituckco
This may be a dumb question, but why do some 7 pin miniature and 9 pin noval sockets have a center post? Is it just an extra lug for convenience or does it have some other special purpose? How is it usually used?
Hello,
It can indeed be used as a convenient tie point. Also, in some high-frequency
applications, it provides some shielding between the pins. An extra
shielding plate can be soldered to this post.
While it could be used for nearly any tie point application the traditional use was for a local star grounding point. And, yes, sometimes shielding was used at that point, usually that the tube socket was located in a notch in a shield partition. Tube socket pins that were to be directly grounded were simply folded in and soldered there.
There are a few tubes that actually have a center pin, but I've never seen one used in audio.
I usually use it as a ground point. I have a 9 pin socket that looks like an 8 pin socket but instead of having the large stabilizing piece of plastic found on octal power tubes, it had another center pin-- not a center post as we're talking about here, but another pin. I have no idea why.
The 6C9 is one such tube. It's a dual RF tetrode and has ten pins in what looks like a std nine pin pkg. Heath and some other brands of low cost FM tuners used them in the front end. One tetrode was an RF amp and the other was a self oscillating mixer.
