Ceramic cart recommendation
Shockmaster
I have a Kenwood KD 770D and I recently picked up an all tube mono amp. I need to pick a mono/ceramic cart for the mono phone stage. Can anyone recommend a good cartridge for the table, I’ll post a photo of the arm and table. Thanks so much!
One of the better Sonotone carts, strapped for mono.
Check with The Voice of Music site for availability.
You could use a pre-amp with your Shure cartridge, bridge its output to mono, and then connect it to the tube amp.
Can I assume your new tube amp has a phono stage designed for ceramic carts and not magnetic?
Grado and AT make mono cartridges. Ortofon might, too.
If you insist on a mono ceramic, you can use any line level input on the pre-amp (tuner, aux, CD, etc.).
Not exactly. A ceramic cartridge requires a high input impedance (1 megohm or more), or else you'll get a loss of bass response. A tube amplifier naturally provides this high input impedance, but a solid-state amp does not, unless it has an input specifically designed for a ceramic phono cartridge.
Then the OP is better off with a Grado or AT mono magnetic cart.
