Ceramic disc capacitor how to test ?
grabread
Hi, do you test a 50v ceramic disc capacitor with the capacitance setting on a multi meter?
Also does the value need to be exact ie can I substitute a 8pf for a 6pf
Sorry to ask such basic questions but I am new to this but learning all the time
Thank you
Yes, your cap test setting should test that. Just keep in mind it will be only a test for capacitance and not other cap tests like ESR.
Whether you can substitute depends on where in the circuit it's located. 8 pf is 30% higher than 6 pf which is beyond the typical 5-20% tolerance range for caps. If it's in any kind of tuning circuit it may change the alignment.
No idea what multi meter you are using, but some will be totally incapable of making an accurate measurement of a capacitor in the low pF range...
