The desireable D series woofers are the ones marked w 152WR and WZ2010 cone respectively. Those were primarily early ones that had extended pole plates, and they could dip lower than the later 152WD. Also, find the Dhorn tweeters that were Japan produced and not Taiwan. If you put together a pair of D9's with the 152WR woofer, Japan tweeters, thick-wired X-overs, and early midranges with plastic screens and not the metal mesh ones, then hook them to vintage power, such as a SX-1280, SX-1980 Pioneer, or a Marantz 2385, 2500, 2600, or even a Kenwood KR-9600, KR-9050, then EQ them with a Mic and pink noise equipped parametric equalizer, and OMGGGG!!! Some of the cleanest sound waves you will ever hear! My 1985 D9's that I bought new, were equipped with the 152WR woofer and later I added the Japan tweeter. Holy crap did they sound good!did you by chance get a pic of the back of the magnet? for the codes?
The wood laminate vinyl clad cabs were mostly throughout D9's life, from 1984, to around 1989-90, when they intro'd the black ash vinyl clad cabinets, and they began to out-sell the wood laminate ones, so they made the switch to all black from then on, so the last few years of D9's were black for this reason. As for the special edition D-9, this was the PD-9, which came around 1988-89, and was first produced in the wood laminate color vinyl, like the regular D9, but then they intro'd the black ash covered cabs, and they also out-sold the wood colored ones, so they stopped making them in the wood vinyl clad, and PD-9's were all black ash cabinetry. It is said that black PD-9's are pretty rare, since they discontinued them right after the switch to all black. Overall, PD-9's are kinda hard to find, but they are out there. Around the time PD-9's disappeared, they intro'd the 380SE, which was similar configuration as PD-9, but with an improved radiating, bullet Dhorn tweeter., from then on, most of CV's speaker lines were only available in black ash, as they still are today.Not to bump an old thread, but what is the difference in the wood coloured D9 and the black D9? and also what is the "special edition D9" thanks
Wow, never heard that line from any HPM-100 owner. I've heard them and thought they sounded really nice. Great Bass, and accuracy. Perhaps something is amiss with your pair and they need a tune up?Thank you for that Tuna, being a fellow 1980 owner, my hpm 100's just aren't cutting it for me anymore, I found a set of clean VS 150 the vegas.. and I read great things about them, any insight on those?
VS-150's are ok, they have a weak tweeter though. My favorite newer CV are the late 90's early 2000's E series. E-312's, E-712's, E-315 & E-715. I had some E-312's I bought new back in '99. I had them for over 10 years, and they sat in my basement in original boxes, unused. Pulled them out and played them on my 1980, and all I can say is they were very clear, clean, and mean. Here's my old thread:
http://www.audiokarma.org/forums/showthread.php?t=310340
Was it really necessary to necro this thread, given how many similar new threads we've had recently?
I'm not sure about the fuse in the D-7. I will say that the stock fuse for the D-9 is 2.5a slow-blow. I was blowing fuses somewhat regularly, and after consulting with CV Tech Support, I upped the fuse to 3a slow-blow and never had any problems afterward.
3a fuses are blowing.
You are using Slow-Blow fuses right?
Maybe time to start pulling drivers and check the voice coils for dead shorts....have you put an ohm meter across the input terminals after a fuse replacement- what reading are you getting? Smell anything burnt? Should not be difficult to figure out.
DC
Ah yes! Sun TV sold a TON of audio equipment in central Ohio during the 70s, 80s and 90s. I spent a lot of hard earned dollars there.Chest thumping bass on hard rock music!, like at a concert!! But the mids and highs at high volume really start to hurt the ears! Probably best in a very BIG room. Overall they sound decent. A buddy of mine worked at sun tv around 1990, he said they sold like hotcakes at around 1000 bucks a pair, and hated moving them giant things! Im surprised they sold for that much, he could be wrong, maybe somebody on here can confirm there original selling price, i would kinda like to know for sure.
I don't know where the 2.5a fuse came from in the D-9's, every single D-9 I've ever seen, is 3a. D-7 should be same as D-9, 3a.Was it really necessary to necro this thread, given how many similar new threads we've had recently?
