cerwin vega sensurround earth quake woofers
Formeruser1
hello everyone i have to original cerwin vega sen surround power amplifier. cerwin vega A-2200 IS THE MODEL. and i recently got 1 cerwin vega 18 model number 188eb. well i was wondering if any one knows the model number to some of the original sensurround woofers they were using back in the 70s in the movie theaters for the movie earthquake.
Here is a list of 18 inch tranducers that will give you the best performance when using Scoops/Rear Loaded Horns & Earthquakes/Folded Horns
Cerwin Vega 188 EB
Cerwin Vega 189 ES
Cerwin Vega 189 JE {4 ohm}
Cerwin Vega 189 SE
Cerwin Vega 18S4 {4 ohm}
Cerwin Vega 18S8
Thanks for the stroll down memory lane. I remember them well. The first really tight deep bass I heard.
I'm sorry I can't answer your question.
The thread killer strikes again.
Th
Cerwin Vega 188 EB
Cerwin Vega 189 ES
Cerwin Vega 189 SE
Cerwin Vega 18S8
The 188EB is not a subwoofer. It is designed for use in full-range systems using a 5 cubic foot ported box tuned to ~50Hz, like the PD-18 3-way system.
The original Earthquake woofer was the 189E as used in the Sensurround horn cabinets.
Cerwin-Vega called it the L-48SE in their 1977 Pro brochure. The "SE" meant "Special Extenders" that were included to make the horn longer. it consisted of a full sheet of plywood and end pieces that were used with a pair of these cabinets laid down side-by-side making them 8 feet widex21" high. The 4'x8' plywood sheet connected across the top front edge pointing up at an angle with fitted pieces on the left and right completing the horn extension. There is a picture of these installed somewhere on a speaker forum. I'll look for it and re-post it here if I can find it.
I have a 189E and a Sensurround Model M horn.
Click on the thumbnails to see high-resolution pics:
I found this paper written by E.J. Cerwinski and G.R. Lewis. Published in the April, 1975 edition of Audio magazine. Thanks to fellow forum member Pete B for the link!
C-V placed a full-page ad in between the pages.
Here are screenshots in .png The .pdf is better but the file was too large to post. I can email the .pdf to those who are interested. Send me a PM here.
Cerwinski Sensurround system pg1 Audio-1975-04.pdf.pngCerwinski Sensurround system pg2 Audio-1975-04.pdf.png1975 C-V Home+Pro full page ad Audio-1975-04 pg49.pdf.pngCerwinski Sensurround system pg3 Audio-1975-04.pdf.pngCerwinski Sensurround system pg4 Audio-1975-04.pdf.png
Here is a genuine dimensional drawing of the Sensurround Model M (Modular) cabinet as shown in the article I posted above.
It is labelled "L 48 SE" which is the model number Cerwin-Vega gave it in the Professional Products line.
The horn mouth extender is separate from this drawing and can be constructed using the dimensions in the article above.
Corner installation requires a different extender to fit the corner and close off the top of the stack. It is not shown in the article above.
Note the added vertical brace dividing the two horn paths in the 2nd drawing view.
This brace is not present in the early version of the Sensurround cabinets.
Oddly, the dimensions are expressed in centimeters.
This has all been so amazing to read and learn about. I just hauled 8 of these home into my garage from a remodel I was doing recently at a local, what used to be, nightclub. After seeing what was in the monster M cabinets and going down the rabbit hole of these forums and stuff it's blown my mind. I'm not sure what I'll be able to do with all of them. I might keep 2.
