mprince
Since I've had my Technics SL-1200, I've aligned my cartridge like a lot of other people do - with the Technics alignment tool (which I think I used once) or a dial caliper to get the recommended distance from bayonet plug/gasket to the stylus. Then squaring up the cartridge by eye. Always have had good results with this and understand that this is a Stevenson alignment spec.
Yesterday I was going through my cartridges and realized that there was a 2-point alignment protractor in my M97xE box that I had not seen before. I tried to print out the Baerwald protractor from VE as well, but could not get it to scale properly on my printer, so I decided to give the Shure (also Baerwald/Lofgren A) protractor a try.
All I can say is WOW. Much better sound, especially on the inner grooves. The alignment is easy to dial in with my non-Technics headshells, as they allow the cartridge to get forward enough in the shell to hit the marks on the protractor. With the Technics shell, it's cartridge dependent. The M97xE was not a problem, but an older A-T cart I have (PRO13E) is all the way forward in the headshell slots to get there.
Bottom line, I am now a believer in the protractor (and this alignment). I won't set up another cartridge without it!
