cow dog
Problem: channel cutout on two of my solid state amps
Equipment: Carver M-500 T amp & TX-11a preamp
Topping T22 dac/amp
Hey there y'all, it's been awhile but I thought I'd check in to see if any of you have had this problem that's been dogging me for awhile. Pardon me if it's been dealt with in other threads, but it first cropped up in my Carver stack some time ago, and even after a cleaning/restoration by a local "expert" (not so sure about him now).
Here's what I'm getting: upon a cold start, the right channel volume will be very low. I'll try to balance sound by turning the balance knob about halfway - this normally does the job. Other times, the right channel seems to be out completely. I've discovered that if I briefly pot up on the volume (both channels) very high and then back off, it will "kick in" the right channel and I'll get normal balanced stereo again.
On my Topping T-22 (driving Klipsch bookshelf speakers), I've noticed a similar thing - low or missing left channel. Since that one doesn't have a balance knob, I'll just pot up volume very high for a second, and that channel will kick in for me and it'll be all right.
Any ideas? Is this a repair or maintenance scenario? Thanks for your replies and I pre-apologize if this problem has been dealt with elsewhere on this site.
Topping T22 dac/amp
