sdinfoserv
I'm chasing a dim bulb short on a Nikko sta-4030.
I think the short is on the main amp PCB.
dim bulb is 100w, the Nikko is only 18wpc.
Reg PCB Main Amp
pins pins
8A,B Left, right input from tone board
8C,D Left, right output (to phone jack/speaker selector)
9C ---> 8E,F power inputs from reg block
9A ---> power 2 tuner PCB
9B ---> power 2 EQ PCB + tone PCB
all connected - dim bulb lit, case lights off.
disconnect 8E,F dim bulb dark, case lights on.
if power to main amp connected, dim bulb lit, no case lights on.
does not matter if power to tuner or EQ/Tone connected or disconnected
does not matter if inputs from tone to main amp connected
does not matter if speaker outputs connected to main amp.
dim bulb lit with any connection combinations to main amp.
Can I safely assume the short is on the main amp PCB?
on the main amp PCB:
I've replaced the caps and tested the transistors with a peak atlas DCA75 pro. It finds no issues. I've cleaned and put new thermal paste on the output transistors and replaced the mica insulators. None of the resistors look burned, 80% of them I've tested out of circuit and they're within spec.
I've double (and triple) checked the caps polarity, transistor pinouts, and the traces for solder bridges - none found.
Suggestions?
Reg PCB Main Amp
pins pins
Suggestions?
