Cheap Component Tester
After using the "no case, no probes" unit for some years, I know it's not ideal, I prefer a unit in a case, but do you know the difference between all those models and the different chips?
I'm considering a DIY kit, perhaps I can get a more expensive unit for less. I can solder a couple of resistors and transistors. But I don't know if a "$40" tester is better than a "$10" one.
Its hard to fault them at the price point but the leads and the mini clip grabbers are pretty flimsy
I'll say. I've already had to resolder the wires onto 2 of the 3 mini grabber heads; the third can't be far behind. But I do like having this thing around.
Just discovered this series of videos doing a shootout of the modern, available component testers. Includes a link to a 3D part you can print that gives you a case for the open-frame no-case testers.
That YouTube channel also has a video showing off the PC-based capabilities of the DCA75
Finally bough this 2 from the same vendor, let's see .. One with a square wave generator and freq counter, the other similar to my old one, just in case, I know that one works OK. I think the large one is a DIY Kit. $23 for both units shipped. (NO AFFILIATION)
Without case... I've chosen an extra unit instead of the case. I'll DIY some case and probes down here.
I find it useful too if I'm subbing a transistor with a replacement with a different pin out. I test original, then replacement. It help me keep elements straight ( nearly foolproof)
The cheap testers work well for showing the current values for resistors, capacitors, diodes and transistors. They are plenty accurate for repairing stereos.
That being said, I use a higher quality digital multimeter to measure voltage and current, so when I need to measure resistance I use that same higher quality DMM instead of the cheap component tester.
When I need to identify a semiconductor like a diode or transistor, especially if I'm matching transistors, I will use my Atlas Peak DCA75 instead of the cheap component tester. They seem to do a similar job, but I trust the DCA more. I relied on the cheap component tester for doing these jobs for a long while until cash was available for the upgrade.
What I don't have is an ESR meter and I think that's ok for me. I I initially thought I should get one but I stalled the purchase decision long enough to realize I don't really need it. If there is an existing electrolytic cap in a unit I'm working on, I'm going to replace it no matter what the ESR is.
Sorry , the cheap tester. I'm not knocking it but wouldn't use it to see if caps were in spec. (at least mine isn't accurate)
