I have most of the mods planned out already and most of the parts are already here.
The major shortfall of these speakers is the bass response. Although these have been my main 'listening' speakers since the 1990s, since I recently got the L19s and a pair of 3411b, the Yamahas now sound thin and cheap in comparison. I think the mid and high are OK. I think all the drivers are as good as one might have in an inexpensive home build setup, so no plans on changing those. I did read through 1% of the over 600 posts on the Econowave thread, but I think I'll stay with the original 3 drivers here and not go that route.
These are the proposed modifications:
Remove the drivers from the cabinets.
Put a few drops of super glue in each screw hole to stiffen up the threads in the particle board.
Run a line of glue to seal all the inside joints.
Add pads of 3M Sound Deadening material to the back and sides from the inside.
Rewire the speakers with generic 3-way crossovers from Parts Express (part #260-230)
Upgrade the wire terminal connector on the back.
Add a wooden brace from front-to-back under the weak area of the front panel between the three drivers.
Add pink fiberglass wool.
Re-assemble the drivers in the cabinet with foam rubber gaskets.
I'll post my results as I go.
All suggestions form those with experience in speaker design/construction/modification welcome and appreciated!
