CorrectI would jump red to red and black to black to get 115V input for the Primary coil and leave the purple alone.
As your looking at this diagram... https://www.antekinc.com/content/AS-1224.pdfThen for the secondary,
Correct]
Thank you, avionic for checking over this for me! I really don't want to see any smoke when the switch is flipped. Even if it doesn't make a difference in sound, perhaps it will make a difference with shielding out some of the interference when the HVAC compressor kicks on. At the very least it will be an experiment.
Not at all, it's on a separate breaker. The unit is on the opposite end of the house as well. The thermostat switch is in the adjacent room though. I took a look at the emi ferrite core data sheets. I'll have to see if I can find the frequency at which it runs at to find the correct core to use. Again, this has been quite helpful, thank you, avionic! I'm guessing that I would have to wrap it at the source of the noise for it to work.Is the AC compressor on the same circuit as your CA amplifier ? Or in close proximity to ?
Wrap it at the AC entry point on the effected audio gear.I'm guessing that I would have to wrap it at the source of the noise for it to work.
As soon as you gave me the link, I ordered it! Still waiting...patiently! Thank you yet again, avionic!Get your transformer squared away first..
Correct
Wire as a 48vac center tap..
top green wire ----> first AC connection on the bridged rectifier ---- >( yellow on your unit)
the next blue and the next green ----> star ground ( center tap ) --- >(black on your unit)
bottom blue -----> the second AC connection on the bridged rectifier --- > (yellow on your unit)
Correct..For the output, (A) yellow will go to (1) green on the new transformer
(B) yellow will go to (4) blue
(C) or (D goes to star ground) Black goes to (2) blue and (3) green
correctOn the input side, I will connect the two twisted reds to the single red, and the two twisted blacks will go to the single black wire which will plug into the power supply board.
correct
[/URL]
