In the service manual, it says to read and adjust voltage in the power amplifier to connect the digital multimeter between R763(+) and R765(-) and adjust with trim resistor R731 to get 23mvDC. The other side of amp R764(+) and R766(-) and adjust trim resistor R732. My question is R763 and R765 are rectangular resistors as are R764 and R766. They are not pins. What I want to be sure is that I'm connecting to the correct location on the board to get the reading without shorting out the board. This receiver layout is different than a 2230 with separate amp boards. Can someone walk me through this? I can't load a photo of the P700 schematic, for some reason.
