I'm going to be active bi-amping a pair of DIY speakers soon if I ever get around to finishing them, using a miniDSP SHD Streamer for DAC/crossover/EQ duties. Having been so pleased with the Nobsound Dual TPA3116 amp (50Wx2) for several years, I decided to add a second, slightly more powerful chip amp to my repertoire for the woofers. I waffled around a while before deciding to go with the Aiyima A07 amp based on the TPA3255 chip. It just arrived tonight, and I got it wired into the system to compare to the Nobsound on my Forte II's. I'm a couple albums in now....
First impressions is that it's a very good amp from a musical, emotional standpoint. Probably the equal of the Nobsound out of the box, if not even a bit more romantic and involving. Input sensitivity is quite a bit lower on the Aiyima, and it's not as punchy, neither of which I wasn't expecting. I'm using a 24V/5A Acopian linear regulated supply on the Nobsound, and the stock 32V/5A switching supply on the Aiyima, so there's a chance that's part of it. I do have an Acopian 48V/8.5A linear regulated supply on the way already for fun
, so I can see what difference that makes. It's entirely possible that a little burn-in helps as well. And even if nothing changes, I think the miniDSP will mostly mitigate the bass difference once I re-run the EQ program. One might be tempted to run the Nobsound on the 2235H's, but I'm going to bet the extra power from the Aiyima will come in handy.
If I was just single-amping and the speakers were relatively efficient, I'd probably lean toward the Nobsound. It's just a damn fine amp even at 10x its cost. I'm not sure if it's still available on Amazon (if it is, the packaging has changed a bit). The Aiyima is pretty darn impressive in its own right, though, and I don't think you can go wrong with it.
