Good amp for ESL-57's
First of all, if you have ESL-57's, DO NOT ARC THEM. Arcing them can easily ruin the panels. Costs money to fix that!
I suggest using Wayne Picquet's zener clamping board, which as far as I can tell will absolutely protect your ESL-57's unless you are driving them at insane levels.
Wayne is one of the most respected Quad ESL rebuilders.
http://quadsunlimited.us/ - I cannot hear the zener boards unless I over drive the speakers- then you hear the amp making some distressing sounds. Very good to have the zener clamping boards. Later Quads all use some kind of protection similar to the Zener boards.
I like the Forte 4a, it is a class A solid state amp, add the Soderburg mods and you have a giant killer. 50 watts/ch at 8 ohms. Very taut bass, and very liquid midrange. Highs have a touch of sweet tube-y sound, very little glare or grain.
Also very good on ESL-57's is the Citation II, and of course do the McShane power supply mods which improves these wonderful amps. You'll generally need to replace filter caps anyway - these amps are over 50 years old! - and the McShane mods offer a better grounding scheme as long as you're in there replacing filter caps.
But I really suggest not using such high-powered amps unless you have the Zener protection boards.
Another amp that sounds really good and which you can buy cheap as hell is the AMC CVT-2030, which is a Class-A amplifier using MOSFET drivers and EL34 outputs. This is the Rodney Dangerfield of high-end amps, can't get no respect because most audiophiles mistakenly assume high price = good sound and therefore low price = bad sound, which ain't necessarily true. I've seen CVT-2030's go for around $200, and at that price you really can't beat them. I feel the Quads really want at least 50 watts a channel, so any EL34 amp seems just a trifle underpowered to me, but your mileage may vary. The AMC CVT-2030 has great detail along with smoothness and that super-duper EL34 midrange. I have tried this amp with other speakers and it was just OK, but on the Quads it was a real winner!
