Bluesgrooves
Hi all,
I’ve drooled over vintage Denon turntables for years. I finally pulled the trigger on a DP-60L that had been fully recapped. Upon arriving, I found the TT was beautiful and everything I hoped it would be. After setting it up, it almost immediately exhibited the dreaded high speed spinning issue that would crop up intermittently while playing a record.
The owner said the TT had previously exhibited this problem, which was the reason he had it recapped. I sent it back out of fear that the issue might be related to a problem with an unobtainable microprocessor (sad times!).
I’m still in the market for a Denon TT, but this has scared me off from those which might have a problem come up that is unfixable (like impossible to find microprocessors).
So my question is this: which of the flying saucer TTs from the 1970s-1980s have microprocessors that cannot easily be replaced?
I adore the DP-60, 62/57, 72/67, 75/80, but it is my understanding that each of these has a lot that can go wrong. On the other hand, I’ve gathered that other UFOs like the DP-6700, 3700, 2500, 1200, 790 are simpler and less likely to turn into paper weights.
Any help/expertise is much appreciated!
Probably a dumb question, but I hear the terms “IC”, “microprocessor”, and “transistor” come up and don’t know if they are interchangeable or entirely different parts.
still isn't rich enough, as he keeps complaining to the press, who usually report everything he says - it's so terrible being a billionaire!
